James Tabor
Just put the COMPLETELY rebuilt head back on my 45 B. Adjusted valves .020 like the book said. Ran it for a while, let it cool down, pulled the valve cover back off. Seems to be oiling properly and rechecked the valve clearance. Had to readjust two. I have always been told by the "Old Timers" that one should be able to hear the valves/rods clacking because as the push rods heat up the clearance deminishes and the extra space is needed to avoid warping said rods. My runs like a top but you can hear them clacking 50 feet away. The JD shop manual advises that valves should be adjusted at .020 unless substantial wear is suspected then you should loosen the rockers until slight resistance is felt when turning the push rods then back off 1/3 of a turn and tighten. I do not detect any wear. Question: How loud should they be?
