Packer Fan
I am in the process of trying to bring back to life my uncles "little tractor". It has been stored in a shed for at least 25 years. I was able to unstick the motor, replace enough electrical parts to get spark, rebuild and replaced enough of the fuel system to get gas and the silly thing RUNS. I want to change all of the fluids. I opened the transmission fill and drain plugs and a small amount of "tar" oozed out.I want to clean the transmission and put some gear lube in it. What should I run through the transmission to clean it without hurting it? What is the best way to flush this thing? When I refill it the manual calls for 90 weight gear lube. Should I put in something heavier to slow the leaks or should I just go with the 90 weight. Is there anything else I should check before I start using this tractor.
