herne19d
I've got a 1945 Farmall BN and when I go to set the magneto, I crank the engine to TDC cylinder 1, and set the Mag so that the rotor points to the #1 plug wire, mount the Mag with the top of it as close to the engine as possible, crank it fully around, back to TDC for #1, and then advance the Mag until the impulse spring trips.
Textbook, except that the impulse spring doesn't trip until the engine is well past TDC.
If the hand crank is at about 4 o'clock (facing the tractor) for TDC , the impulse spring doesn't trip until the crank handle is at 6 or 7 o'clock.
The impulse spring is in good shape, the mag is in good working order, points are new and set, new plugs/wires/condenser/distributor cap, all the things.
It starts with the starter but I can't crank it by hand to start it.
It also doesn't seem to have a much power as it should.
So, I'm wondering if, the last time it was rebuilt, if the timing marks on the magneto drive gears weren't lined up properly? I can't ask the guy who did it because he died about 4 months ago.
Any ideas or advice would be welcome.
