1947 Case SO Governor Problems
Anonymous-0
When I go to give the tractor throttle it will rev up but right away, the governor pulls it back to idle. The throttle linkage only will go to half at the control lever by the seat. But I can go to the carburetor side of the tractor I can pull the linkage and you can feel the governor kick back in and try to pull back to idle. What should I do?
I suggest you buy a service manual for it and go through the throttle and governor linkage adjustments laid out in the manual. Should take care of the problem.
