old
- Location
- Camdenton Missouri
So I got the carb and linkage in today. Put the carb on and rigged up a small gas tank to test start it. I has good spark and gas flow to the carb but little to n suction at the air intake. I tested compression on a couple of cylinders and had zero compression. Tried to fill the cylinders with ATF ad n 2 ATF ran out of the carb. Put all the plugs in and pours some ATF down the exhaust and had ATF out the carb again. So I am thinking I'll have to pull the head off due to sticking valves.
Does i sound like I am on the right track??
