I had a 5 foot brush hog on my 8N over the weekend, I was using the lift control to keep it up a ways in tough grass, I went to lower it and it wouldn't tried going up and it did, but then wouldn't lower. If it disengage the PTO or shut of the tractor it would eventually leak down, but as soon as I engaged the PTO with the tractor running again, it went back up to the top. I searched here and learned enough to remove the right inspection plate and pus back the arm, I had to use a small crow bar and it came down fast when it did. It worked normally after that, but I didn't use the lift anymore. Still seems to be working fine. Was it simply hydraulically locked with too much weight? I had this happen in the winter with a boxblade and flipping the touch control lever forward would make it work, that had no effect this time. I took a video with my phone through the inspection plate hole, it is two complete cycles of teh lever, does everything look normal in there?
https://drive.google.com/file/d/0B1g8aLr20f7kaWE5Zktwbm5TNlU/view?usp=sharing
