1949 8N pto extension??
Wondering if ford ever offered a pto extension that bolted on. The tractor has been sitting for years, went to get it out of the shed and found this:
about 14" long
same 4 bolt pattern that is around the original pto shaft
painted ford red
has a female end that slips on the original shaft
has a regular pto male shaft at the other end
grease fitting in the cast iron housing that i assume has "carrier" bearings in it
Wish i had a picture for everybody. Not too familar with fords. Any ideas on what this is?
Is this what you have?
Dearborn accessory for use with pull behind PTO driven eqmt such as combine. Extended & converted to 1 3/8 size and dimensioned to meet new (at the time) ASAE standards.
Thanks for the info. That picture is what I have. Just missing the safety shield. These must not be rare. Are they worth anything?
