JasonFedewa
Having some carb (DLTX 71) issues with my 1950 A. When I crank the motor I get gas coming out of the bottom of the throttle shaft. Carb doesn't leak otherwise. No white smoke from muffler & doesn't fire. I do have spark. I've cleaned all the secret passage ways, adjusted the float so it is 1/2 inch from the top, tested the float and it doesn't leak. Also tested the needle and seat. They tested good but I tried with another spare needle and seat with no change. I've heard that the baffle vents can cause odd issues but they don't seem to be clogged when I spray carb cleaner through them. What else is odd is that the plugs never get wet. The gas must be going into the crank case. I plan to change the oil but want to figure this out first. Was running before I replaced the throttle shaft, bushings and cleaned the passage ways due to poor running. Really at a loss but I am no expert.
