1952 VAC brakes
dave39B
Hi guys I have a 52 Case VAC.I was looking to fix the brake on the right side and I was looking at the housing that I need to take off to get at the brakes.I looks as if when I take the housing off that there might be transmission/rearend oil behind it that will drain out with housing removal.Is this what will happen.Thanks in advance
Dave
There is a bearing support behind the housing that has a seal in it. You will be fine removing the housing. Only oil you will get it what has leaked past the seal.
The last set I did I got the linings from CASE, but the old ones you needed 2 linings per side and the new ones are one per side.
