Bolt-Action
Okay, I apologize now for the long post, but bare with me.
I've got a 58 Ford 641 WM that I'm at my wits end with and I'm ready to push it off a cliff I'm so dang frustrated!
Several months ago I picked up my 58 641 WM with a Du-Al 150 loader than was running-barely for $1500, not the prettiest thing but a "working" project.
Owner told me it needed a tune-up as it was running rough and hard starting.
I got it home and immediately replaced the; points (.025), condenser, plugs, plug wires, coil, oil, oil filter, fluids, several hydro lines, rotor, dizzy cap, cleaned air filter etc.
It seemed to improve it quite abit for maybe a day of two, then it started running rough and hard starting again.
I changed the condenser (I suspected it was faulty out of the box) and pulled and rebuilt the carb. It seemed to help for about a month and I noticed some garbage in the sediment bowl, so I pulled the gas tank (found some interesting things lol) and cleaned it out and rebuilt the carb again, blew out the fuel lines, checked and cleaned the fuel screens, changed plugs, points, condenser, rotor, ignition switch (the switch was real loose and sloppy) etc. and again, it seemed to improve it and the 641 ran great for maybe a month maybe 2.
Went out to start it and use it (it gets used about 2-3x a week), it began idling extremely rough, almost like an occasional miss. And then it died and would not start, it wouldn't even try to start, just crank.
I knew it was getting fuel so I opened up the dizzy, the points looked ok, but I replaced them and the condenser and rotor again when I noticed the copper "strap" that connects the points and condenser to the dizzy stud (that the coil wire hooks to) was broken and cracked in half. I looked for a small, thin sheet of copper to make my own strap but couldn't find any copper sheets. So I grabbed a spare big block mopar distributor I had laying around and pulled the wire out of it. I inserted it into my 641's dizzy and made sure the rubber isolator was in place to prevent any contact and hooked the condenser terminal and the terminal on the mopar wire to the points and hooked the other end of the wire to the "Dist" side of the coil. There's no metal contact, the wire is ran straight from the points (with condenser), out the dizzy to the coil.
I attempted to start the 641 today and it fired right up and ran like a champ for about 30 secs then died and it would not fire again, it didn't even try to fire again. I replaced the condenser again and attempted to fire the 641 again and it fired right up again for about 10secs, and would not fire. I again suspect I blew the condenser (?).
Do I HAVE to use that thin copper strap? What am I missing?
Thanks for any assistance or help, I'm smacking my head against the wall with this thing.
