I have a 1958 MF65 gas standard with a well worn engine. I am trying to decide whether to rebuild or not. Full restore is not really an option but I could spend the time to rebuild and make it a solid runner again. I used it to hobby farm and run a 12 ft batwing mower. No need for loader, etc. as I have other equipment.
I am an experienced gas engine rebuilder, but mostly cars, trucks, snowmobiles, bikes and anything else that has combustion engines that quit running well. While I would love to have a fully restored tractor (some sentimental value) that is not in the cards for me. I started down that path 15 years ago mostly cleaning, blasting and repainting part by part. Did the whole front end, engine and hood but stopped at the transmission for some reason. A whole lot of time. The Quality Farm and Fleet paint has faded worse that the factory paint I blasted off.
This tractor has had blow-by for some time now and should have been rebuilt some time ago (shame on me). I finally tore into it to see how bad it was.
Here is what I found...
[list:6517bc348a]Valves and guides are toast but rocker assembly and lifters okay ($220 for full valve, guide, spring kit).
Sleeves worn beyond tolerance - 0.080 over ($500)
Pistons worn beyond tolerance - 0.040 under
Crankshaft main and rod journals worn beyond tolerance - 0.020-0.060 under ($600)
Main beds - within tolerance and usable
Big ends - within 0.007 or less - can clean these up
Camshaft okay - needs new bearings
[/list:u:6517bc348a]
Hard to believe this engine had 185 psi on all 4 cylinders. It has the High Altitude pistons stamped Conformatic made by Atlas.
The crank bearings were really worn (copper showing almost everywhere) and explains the crank wear. Pistons, rings etc show no damage just wear.
So I need to decide whether or not to rebuild or look for another machine. I haven't torn in to the back half yet, but expect to need parts, seals throughout...
[list:6517bc348a]Power Steering - needs seals and cast support is cracked quite a bit (maybe could weld up)
Transmission (front seal leaking)
Clutch (looks okay but might as well replace)
Steering box (leaking oil down transmission)
Hydraulic pump is weak (may need a kit or even replacement)
Brakes (new lining likely)
Back end (planetary, shafts, seals, etc.) seems in pretty good shape
PTO needs attention (not sure what, but doesn't shift well and kicks out)[/list:u:6517bc348a]
I think I can rebuild the engine for under $2K (with new aftermarket or reconditioned stock crank). I just don't know what I will run into cost wise in the back half. Another $1K, or more???
So looking for feedback for those who have rebuilt Continental gas engines of this vintage as well as rebuild/repair of the rest of these machines.
What would you do in this situation?
