1963 case tractor info
Anonymous-0
does anyone know how much propane a 1963 case 830 tractor holds?,does it have a live pto,always running????...if not how do you make it stop???
propane tank is 24 dia x 29 lg...
and any info you might have on it...
thanks,
richard.
Live pto does not mean always running. It means pto can continue running even when you stop tractor forward motion. There is a lever between your legs that puts pto engage and disengage. Pull up to engage push down to stop. That model Case was notorius for having the pto continue running even with lever down in off position. You need a new pto clutch brake. Be very careful with that pto untill you get it fixed.
