Beavonthebayou
Hi Y'all,
I have a 1963 Ford 2000 gasser, converted to 12V w/electronic ignition. It's been running pretty good, but a day or so ago, I went out to start it, and nothing...an occasional click from the solenoid, as I wiggled different wires or the battery ground. It seems as if I have a grounding issue somewhere, and I'm trying to figure it out...any help would be much appreciated.
OK, here is what I've found so far.
1. Key off - I have 12.63V from the battery, to the hot side of the key to the top post of the solenoid, to the alternator, no voltage to the switched side of the key or downstream.
2. If I test the unconnected lead from the switched side of the key, with the key on, I show 12.63V
3. If I connect the switched side of the key to the post that connects it to the terminal on the solenoid (I believe the S terminal), with everything else connected, and I turn the key to ON, the solenoid may or may not click, and nothing happens when I depress the starter button, but it seems like the voltage in the system disappears from my multimeter
4. HOWEVER, for a while, if I switched the key on, the starter would automatically start cranking, and the tractor would start, but the starter would continue running until the key was switched off. I disassembled the wires, and when I put it back together, it wasn't doing that anymore.
5. Just before I came inside, I connected just the switched side from the key and the lead to the S terminal, left off the lead from the coil, switched on the key, and for a while had 12.63V to the top post, to the S terminal, to the bottom post, and to the starter, but no cranking at all, and depressing the starter button didn't do anything.
6. I know the starter spins, and cranks the engine just fine.
7. The tractor doesn't have any lights or extra stuff hooked up
Somewhere I must have something grounding or shorting, but I'm just not sure where.
It does have some fresh parts, including a brand new ignition switch, and a new solenoid (I've tried two different new ones, one from NAPA, and one from TSC). The battery cables are pretty tired, and I do have some new ones, but I decided that since I was getting voltage, I might be able to hold off replacing those right now.
Thanks in advance for any help. I really appreciate it..!!
Joel in Louisiana
Joel in Louisiana
