1963 Ford 2000
Anonymous-0
i would like to know can u incage the PTO without it running that is will u be able to pull the cable out without it running thanks Randy
(quoted from post at 21:14:37 06/30/11) i would like to know can u incage the PTO without it running that is will u be able to pull the cable out without it running thanks Randy
Randy,
I little short on info, but [u:5f00cd933c]IF[/u:5f00cd933c] you are asking about the independent PTO on a Select-o-Speed tractor the answer is yes and no. Yes, you can pull the cable and "engage" the valve that sends fluid to the PTO clutch, but without the tractor running, no fluid, no engagement, BUT, you can pull the cable.
chris
