1963 john deere 400 backhoe
mtmgirl
We are having a problem with this old jewel. It will not go in forward or reverse. The clutch is engaging and it has a brand new pump on it. Any ideas on what it could be? Any help will be appreciated.
Check the linkage on RH side to be sure it's operating correctly. Linkage has a history of groove pin failing. How long since hyd filter was changed & hyd sump checked/cleaned?
My father owned a 1969 john deere 400 backhoe and I spent many many hours digging cellar holes and trenches with that machine. Definetly check the sump screen, pull the hose off, remove the nipple, and actually pull it out and check it! Good luck
(quoted from post at 17:17:52 03/25/15) We are having a problem with this old jewel. It will not go in forward or reverse. The clutch is engaging and it has a brand new pump on it. Any ideas on what it could be? Any help will be appreciated.
The parts manual is free on the Jd web site.
The nice folks at 1-800-522-7448 have real JD operator's and service manuals on CD and hard copy.
http://jdpc.deere.com/jdpc/servlet/com.deere.u90490.partscatalog.view.servlets.HomePageServlet_Alt
She is a 1965 to 1971.
Front pumps are often replaced with nothing wrong with them. The front pump requires oil to be pushed up to it from the transmission pump/filter/screen/valves. The front pump could have it's drive shaft disconnected and it should make no difference to the forward/reverser.
John Deere 400
1965 - 1971
Industrial tractor
Manufacturer: John Deere
Factory: Dubuque, Iowa, USA
Variants:
2020: farm tractor
John Deere 400 Engines:
John Deere 3.3L 4-cyl diesel
John Deere 3.0L 4-cyl gasoline
Capacity:
Fuel: 19.5 gal [73.8 L]
Hydraulic system: 10.75 gal [40.7 L]
3-Point Hitch:
Rear Type: II
Power Take-off (PTO):
Rear PTO: optional transmission or live
Rear RPM: 540, 540/1000
Mid PTO: optional live
Mid RPM: 1000
Dimensions & Tires:
Wheelbase: 82 inches [208 cm]
Weight: 4720 to 10500 pounds
Front tire: 7.50-16
Rear tire: 13.6-28
John Deere 400 attachments:
front-end loader
backhoe
John Deere 400 Power:
Engine: 59 hp [44.0 kW]
Mechanical:
Chassis: 4x2 2WD
Final drives: planetary
Steering: manual
power optional
Brakes: hydraulic wet disc
Cab: Open operator station.
Hydraulics:
Type: closed center
Capacity: 10.75 gal [40.7 L]
Pressure: 2250 psi [155.1 bar]
Valves: 1 or 2 optional
Total flow: 6.5 gpm [24.6 lpm]
13 gpm [49.2 lpm] (optional)
28 gpm [106.0 lpm] (optional)
Electrical:
Ground: negative
Charging system: alternator
Battery:
Number: 1 (2 optional)
Volts: 12
B and D, your reply is not quite correct... the reversers on those utilized hydraulic pressure to operate. I have had a hydraulic pump coupling fail on those more than once. And when it does, you will no
longer move.
(quoted from post at 17:44:40 03/26/15) B and D, your reply is not quite correct... the reversers on those utilized hydraulic pressure to operate. I have had a hydraulic pump coupling fail on those more than once. And when it does, you will no
longer move.
I also think trans pump not main hyd pump supplies oil to hyd reverser.
Could be, but I seem to remember not being able to move. Maybe because the loader was on the ground. I try to forget some of the rotten stuff...
