1964 Ford 4000
Anonymous-0
I have a 1964 Ford 4000 Diesel. My tractor has the "tricycle" front tires. I have seen a more common version of my tractor same year with the front end and tires wider. What was the tricycle used for and why make it different?
Narrow front or tricycle front is called a rowcrop version. Gave you more clearance under the tractor for working corn, beans, peanuts, cotton. Many times those types of implements where mounted to the frames that are specific to that tractor type. Also these tractors could be used as a base for a 2 row mounted corn picker. The narrow front went between the 2 rows being picked. Modern chemicals have eliminated much of that type of work, as have modern combines.
I'm sure others can come up with more things that these old tractors could do.
I owned a Ford 7000 row crop. It had a wide front but a narrow front was an option. Because of the higher ground clearance, it was great for putting fertilizer on corn after it was up. It also was better for making round bales as a large windrow would pass under the frame.
I hope you enjoy your 1964 4000. I have a 64 4000 all purpose.
Keith
I think Keith explaned most of it. The row crop desine gives yopu better groung clearanc like on most modern day tractors and the narrow front alowed for front mounted implaments suchas pikers and cultavaters.
Your row crop tractor differs from a standard in more ways than just the front end. The rear end sits higher as well: You will note that there are gear boxes outboard of the diffferential that offset the axles by several inches. These gear boxes are called "final drives". (I believe the ring gear is on the opposite side of the tractor from a conventional tractor, since the final drives reverse the direction the axles turn.)
There is also a "wide front end" variant of the row crop, which has a wide front axle in place of the tricycle front end. Row crops can be converted between wide and narrow front end, but cannot be converted to or from a standard front end.
The tractor splitting procedure is different for a row crop versus a standard. The row crop has a frame rail around the engine that the standard lacks.
You'll find that your tricycle front end can turn much tighter than a standard. It can easily turn in its own length with application of brakes.
