I have a 68 4020 that runs great. The only prob with the tractor is getting it started. I converted it to 12 volts but it still has to be ethered or it will not start. It doesnt matter if it is 90 degrees outside i still have to use starting fluid. Once the tractor is running, it runs perfectly fine and is very strong. Im not sure if it is a timing issue or fuel issue. Do any of you 4020 fans have any suggestions or ideas?????
after you check out timing and fuel you may want to pull the head and check valve height very cricel seats and valves correct for starting
If you are using ether to start when warm, the top rings are broken & compression is low. It will still run strong on the second ring.
I would check the battery cables also. You can run a jumper cable from the starter sol. to the battery to see if starting improves.
I have a 1965 4020 that was converted to 12V last year. It does not start the greatest now, but does not need ether to start. We plug it in if the temp is in the 50"s. How did it start before the conversion?
David,
What starter did you put in when you converted? Mine is weak in my opinion but I can start no ether or plugged in down to mid maybe low 30s. Definately 30 or below is ether time and 10 or less I have to add a 3rd battery to add CCAs to get it to start. I am looking at a few different starters to change to in mine. Probably will go to the dealer and see what ones are in stock to look at a measure. I have it narrowed down to 2 that I am pretty likely to go for.
(quoted from post at 22:25:41 01/27/10) I have a 68 4020 that runs great. The only prob with the tractor is getting it started. I converted it to 12 volts but it still has to be ethered or it will not start. It doesnt matter if it is 90 degrees outside i still have to use starting fluid. Once the tractor is running, it runs perfectly fine and is very strong. Im not sure if it is a timing issue or fuel issue. Do any of you 4020 fans have any suggestions or ideas?????
We have no idea of the cranking rpms, battery capacity, starter size or cable sizes. Does it start any better when using a hydraulic pump destroker, costs about $12.00 to find out? Do you at least push the foot clutch down when starting? PS or syncro range?
Why was somebody using ether instead of a block heater? Odds are somebody has smashed the rings and now the engine requires an overhaul.
Has anybody ever been into the engine? Maybe a quicky ring and valve job? As previously stated just grinding the valves and seats lowers the compression and causes starting problems.Due to sinking the valves deeper into the head.
