1968 Case 1030
can you move it by pulling? if can,t suspect oil slinger in trany is bad and siesed up a bearing. it happened to me i8 years ago. some parts you can get new but slinger was not in book common thing with them have to split to fix good luck
It could be caused by a number of things. Did it happen when you were working it, or roading it, causing it to stall?? Did it happen when you shifted it?
Post down on Case board. You could have seized the range shaft gears due to low tranny fluid level, or could have a broken shiting rail or fork. Need more info.
Loren, the Acg.
