1972 Ford 2000 tractor hydraulic problem
Anonymous-0
Oil blew past Nut & gromet of small tubing coming from hyd. motor entering right side of tramsmission. I replaced the nut assembly. Filled 134 hyd oil to proper level. Started engine and could not get any motion to lift. Anyone have any ideas. Does the lines need to be purged? Hyd Motor? or problems in the case...
Please advise. Thanks
Remove the large nut (Drain Trans/Hyd first) that holds the suction line on the bottom right side of transmission.
There should be a screen on the suction nut assy and it is likely clogged. It can be removed and washed off in solvent or mineral spirits & reinstalled. It is designed to catch metal filings and debris From Wear.
It might not hurt to run your 3 point up and down a few times before trying the loader.
The pump should pick up if you are getting good flow from the suction side.
