1972 Ford 3400 grill
Martinfan
I have a '72 3400 Ind gasser. Need a picture, or a source to order a front grill for this tractor. My tractor doesn't have a grill, or any part of original to try and match one. Most sites that carry grills don't list 3400 grills. any help is appreciated.
Might check the CNH parts web site. 3400 is definitely in their parts list (we just looked at - and passed by - a 3400, and I used the site to check on availability of a couple of parts that were worn out on the tractor).
Several of the grills offered for the 3000 can be made to fit but there are some differences in how they connect to the radiator schroud. You can check easily to see where the top mounting screws
fasten. Right at the top or near the top on the sides? Does the grill fit into the bottom of the schroud on each side and is just held in by two screws near the middle of the sides? I believe the 1972 is a one piece with a straighter top than the older ones like on my '72 2000. I have them in stock.
I think you are correct about being a one piece grill. There are 4 mounting holes that measure approx. 16 3/4"oc Horizontal and 9 3/4"oc vertical. Is the one you have in stock a steel grill, or a plastic grill???
