Hobo,NC
- Location
- Sanford, NC
A customer of mine has a 285, it has had fuel leaks sense he brought it. nothing more than a drip every now and again from the pump and some wick'n around the injectors are injector fit'ns...
I have a few times tighten up things but tighten things up are not working anymore. In the pix were I am point'n at it has started to leak bad,,,its not the line,,,, is this a fix that a decent non diesel mechanic can preform....
It also has worn out the left rear brake,,, it squeals and has little to no affect stop'n it... I spec I could do it but not look'n forward to handling those big wheels,,, i spec i could improvise tool'n needed to make life EZ'er
Pix of the pump,,, any advice would be appreciated...
BTW the owner is in Afghanistan serving his county... The wife is keep'n up the farm and depends on this tractor to do the big mow'n chores...
[/img]
[/img]
[/img]
