1985 Ford Van 351 idle Adj.
Larry D.
Ok fellas... I have an 85 Ford Van with 351 Windsor, and Four barrel Holley carb, How does the Idle ADj done in this Engine, It appears (To Me) that the Dash Pot is involved in this , can anyone Enlighten me on this I can't figure it out, the dash pot moves back and fourth looks like it should go up and contact the Idler, but doesn't HELP! Larry KF4LKU
two adjustments ,,Base idle speed,donewith screw on base of carb, Dashpot/solenoid , done with a/c on in gear ,or solenoid energized etc ,5/16th head screw . Should be slightly higher than base idle , don;t have spec handy . Exzmple ,,Base idle 650 in gear,if auto trans, dashpot idle , a/c on ,,in gear , 750 rpm .
Thanks Bryan for reply.....Tis base Idle adj,.. Is it in the side of the carb near the driver??not in the Linkage..Larry
