1993 Oldsmobile Headlights
Last night, comming home from a friends house after dark, I met a car on the road and tried to dim my lights ,only to have them go completely out switched back to brite real quick and they came back on . Tried a couple of more times to get them to work but they wouldn't . No warning , no nothing . Any ideas ? What are the chances of both of them blowing at the same time . Loose wire , blown fuse , bad dimmer switch , blown bulbs ( it uses the halogen bulbs , the type that you just plug in instead of changing the whole assembly , four bulbs , two high and two low beams ) ? The car is a 1993 Oldmobile Cutlass Ciera with a 3.3L 3300 V6 , automatic with shifter on the column ,and with tilt, cruise , power steering . Thanks for any and all help.
Thanks,
Whizkid
When I was with Ford, we had a Tempo come in once with no low beams. One of my techs tore his hair out for a couple of hours only to find both low beams burnt out. It can happen, and might be the first thing to check.
Thanks guys,
Guess what ? Called my mechanic and he said to try what I had already thought of . To check and see if the bulbs were burnt out . I crawled up under the car and turn the drivers side bulb in it's socket bracket and as soon as I turned it it came on . Went over to the passenger side , turned it and then it came on. Put the pass. side back in and turned them off and let set for a while and turned them on and the drivers side worked , but passenger side didn't so I repeated the process and then it came back on. Spayed them both with electrical contact spray cleaner . Hopefully, now they will work. But what are the chances of that happening again ? How did they both lose contact all at once . If one went out with a bad connection, I can understand . But both at the same time ? It could and did happen , but what were the chances. Looks like then , with that thought in mind ,if one shot then the other one would just quite working , just because the other one shot.
Thank you,
Whizkid
It's time for new light sockets. When they quit making good contact with the bulb there's usually no good fix to them. Being the tightwad I am I've tried cleaning, bending, twisting, crimping sockets and it only works for a short time. I've even put a little drop of solder on the center contact(s) on hot burning halogens on combines and it only got me by for a short time. Jim
Bought a Ford Bronco II from a friend a few years back. He told of having a headlight burn out one evening, and the other went out the next morning as he was headed to a store on the way to work to get a new one. Darned if the same thing happened to us afew years later. Burned out just a few minutes apart. always wondered if the one burning out directed a higher voltage to the second. Shouldn"t have happened, but it did.
