4gkjohnson
I have a 1995 Ford 2120 Synchromesh 12x12 HSS and it acts like the clutch is slipping, same in forward and reverse. I want to check the hydraulic pressure to the clutch prior to having the clutch replaced. I have the manual and it says where to put the TEE to attach the gauge to but the threads or size is different than the manual says. The TEE is suppose to go between the HSS Shuttle Control Valve & the Pressure Oil Tube. The local New Holland dealer didn't have any hydraulic line parts that would fit it. I think it must be metric? The closest thing the dealer had was a 14mm. I don't think the TEE is the 7/16"-20 MJIC x 7/16"-20 FJIC swivel as specified in the manual. It is way too tight!
I am wondering if anyone knows? Could it be
14mm JIC male x
14mm JIC swivel female x
14mm jic male (middle)
The flare wrench I used to get it loose is a 17mm.
Any idea where I can get this TEE and the adapter to NPT? The TEE set and gauge at the dealer is $900 and they don't even have one for themselves.
I hope someone can help, my tractor is down.
Thanks, Greg
14mm JIC male x
Thanks, Greg
