OK,I've got 2 unrelated problems with the 2-135 Series 3,so I'll make 2 seperate posts. How much refrigerant does that system hold on the series 3 2-135 air conditioner unit? I hooked a jumper wire to the compressor today,put in two 12 ounce cans of 134a and it cools down,doesn't frost up the lines,but cools. I hooked the wires back together and the clutch still won't kick in on it's own without a jumper. I opened up the top of the cab,have power to everything. Traced everything down and have power to one side of what I think is the low pressure switch. It's the 2 pronged sensor on top of the filter dryer. If I pull those 2 wires off the spades and hook them together,the clutch kicks in and it works. So I assume I either don't have enough refrigerant in it yet of the switch is bad. The manual that they gave me when I bought this thing 7 or 8 years ago isn't for a series 3 and only shows a high pressure switch,doesn't show anything but a sightglass on top of that filter/dryer. When I was looking it over last week,those 2 spades were bent together and touching. I think I probably did it with the pressure washer or something,but now I'm wondering if somebody bent them together to make it work. You'd have thought I'd have noticed before this. Would it hurt to run it with those wires spliced together if there IS enough gas in it and the switch is just bad?
