See the last of my replies to the other thread on here about a 2-135 hydraulic pump, where I talk about Vickers pump cross-referencing.
Can you still get parts to rebuild a Hydraulic pump on a 2-135? if so were can you get them. Thanks
I recently replaced the hydraulic pump on a 2-105. Took it to a local hydraulic shop and replacement parts were more expensive than a rebuilt. check out jerry Stair at ag parts first.
When buying a new pump, be sure to get the right one. There's a cast iron and an aluminum. The fittings are different on them. You can buy a kit to replace the cast pump with an aluminum, but you can't go the other way. A magnet will stick to the cast pump. The end is cast on both, so check in the middle.
