If you grind that soil into powder with a rototiller, it will turn into concrete after the first rain. Conventional tillage is probably the best. Heck if I was just playing around I'd probably plant "tillage radishes" to see what they'd do.It's actually pretty sandy, soft soil. The hunting ground has only been mowed for the last 15 years. It would need some serious work to get it turned I would bet.
read the OP.If you grind that soil into powder with a rototiller, it will turn into concrete after the first rain. Conventional tillage is probably the best. Heck if I was just playing around I'd probably plant "tillage radishes" to see what they'd do.
Just to clarify, you currently have ZERO tractors correct? There's no using what you have.
If you roto till sand it will blow away on you. That and a disc can cause more problems that it is worth. If sod then disc after deep till and cultivate after that. no need to pound the ground into fine powder. Yes radishes would be good for deer plots as well.What would be my best bet for a working tractor for 20 acres tillable? I've had several old Fords. A 4000 4 cyclinder, a couple 961's an 861 and a Jubilee. Those were more just hobbies. Never really worked any of them except for some brush hogging and snow plowing. Now I have a place with some tillable that I may plant some sweet corn, other veggies and then work a couple food plots on some hunting land. The old Fords are really nice to work on but I've seen around here they just can't go slow enough for a tiller which I'm sure I'll need. I've heard the 3 cylinder diesels are slow enough but don't really know anything about them. Any input on models, options, hp or the like is appreciated. Even open to other brands then just Fords. Just looking for something to get the job done and reliable. Thanks! Tom
Do you actually think he can find a L4802 in his $5k range?Kubota..L4802..45 hp hydro
Nope. When I wrote this I new nothing about the $5000 budget.Do you actually think he can find a L4802 in his $5k range?
As has been said above, ditch the idea of rototilling. Vertical tillage would fit the bill quite nicely without the potential drawbacks of moldboard plowing and could also be done with your current Fords.It's actually pretty sandy, soft soil. The hunting ground has only been mowed for the last 15 years. It would need some serious work to get it turned I would bet.
What am I missing here. I see nothing about him having "current Fords "As has been said above, ditch the idea of rototilling. Vertical tillage would fit the bill quite nicely without the potential drawbacks of moldboard plowing and could also be done with your current Fords.
My mistake, I missed the past tense "I've had".What am I missing here. I see nothing about him having "current Fords "
His post is, I suppose, slightly vague, but if you are following the Ford forum as I do you see that Tom may not post a lot but fairly regularly for a long time about various old Fords and has never indicated that he was selling everything.What am I missing here. I see nothing about him having "current Fords "
I don't know guys. If he's going to plant "sweet corn and other veggies" it might be nice to have one that can run a tiller.What would be my best bet for a working tractor for 20 acres tillable? I've had several old Fords. A 4000 4 cyclinder, a couple 961's an 861 and a Jubilee. Those were more just hobbies. Never really worked any of them except for some brush hogging and snow plowing. Now I have a place with some tillable that I may plant some sweet corn, other veggies and then work a couple food plots on some hunting land. The old Fords are really nice to work on but I've seen around here they just can't go slow enough for a tiller which I'm sure I'll need. I've heard the 3 cylinder diesels are slow enough but don't really know anything about them. Any input on models, options, hp or the like is appreciated. Even open to other brands then just Fords. Just looking for something to get the job done and reliable. Thanks! Tom
When I was custom farming for the organic neighbor they had me plant them some tillage raddish. After they grew about a foot deep I would pull some up.If you grind that soil into powder with a rototiller, it will turn into concrete after the first rain. Conventional tillage is probably the best. Heck if I was just playing around I'd probably plant "tillage radishes" to see what they'd do.
There were several transmissions available in the 3 cylinder Fords, 4 speed, 6 speed, 8 speed and the 10 speed Select-O-Speed. The choice of transmission will make a big difference in travel speed.What would be my best bet for a working tractor for 20 acres tillable? I've had several old Fords. A 4000 4 cyclinder, a couple 961's an 861 and a Jubilee. Those were more just hobbies. Never really worked any of them except for some brush hogging and snow plowing. Now I have a place with some tillable that I may plant some sweet corn, other veggies and then work a couple food plots on some hunting land. The old Fords are really nice to work on but I've seen around here they just can't go slow enough for a tiller which I'm sure I'll need. I've heard the 3 cylinder diesels are slow enough but don't really know anything about them. Any input on models, options, hp or the like is appreciated. Even open to other brands then just Fords. Just looking for something to get the job done and reliable. Thanks! Tom
Unless your time is very limited (1/2 day per week), the tractors you already have are plenty for the tasks. You may need implements though.It's actually pretty sandy, soft soil. The hunting ground has only been mowed for the last 15 years. It would need some serious work to get it turned I would bet.
On my clay soil, attempting to use a chisel plow as the initial implement after years of neglect is a "bouncing across the surface" waste of time and fuel.If soil is unusually hard as in not been tilled in years a chisel plow/all purpose plow may soften it up better than a disc harrow.
To each his own. I did have a TO-20 MF that had a lots of guts, very similar to the Ford N series, but lacked a lot of what I wanted in a tractor. Along the Ford line my 3910 tops the list and the only thing missing is a cab and for that tractor and what it does that's OK that it doesn't have a cab.The FORD N-SERIES Tractors, an 8N is better than a 9N, are perfect workhorses for farms small and large. Hobby farms, food plots, gardens, mowing, brush hogging, snow plowing, and more can all be done efficiently on an N. The later Hundred Series and Thousand Series models may be too big for your needs. The bigger 134 and 172 engines consume more fuel for example. An N usea 4-CYL Flat Head FORD 119 CID engine. Easy to work on, parts are available, and can have fun as well. The NAA began using the 134 CID OHV Engine in SEP 1952 and is a better power plant. ALL FORD used the 6V/POS GRN Electrical System but many have been switched over to 12V/NEG GRN by guys. A 6V or 12V setup is what is important. Forget a serial number - means nothing. NOTE: Many DIY 12V conversions are done wrong so you need to get the correct wiring diagrams too. Forget a roto-tiller, N's not geared for it. Early 8N, 47-50 used the Front Mount Distributor - often a mystery to some but the later 1950-1952 8N used a side distributor; a much better system., Find old Dearborn Equipment as a plow, cultivator, disc, spring tooth harrow, to use and you will be happy. The 1st thing to do whatever you get is to invest in The Essential Manuals and read before you do anything. Avoid buting anymnewparst and jsutstartrepacing willy nilly. Old must prove defective before you replace anything and then rebuild the OEM components as they were designed to be. New are mostly junk. A used 8N can go from $1200 to $5000 so ya got to do your homework on seller. Price out new/used Kubotas. A good call but you'll need deeper pockets.
ESSENTIAL MANUALS - FORD 8N-SERIES:
1) Original Owner's/Operator's Manual
2) Original 1939-1953 MPC (Master Parts Catalog)
3) I&T F0-$ Service Manual
#2 and # 3 also required for a 9N or 2N. Get and read religiously B4 anyhing else.
Your Mileage May Vary,
Tim Daley (MI)
TomWhat would be my best bet for a working tractor for 20 acres tillable? I've had several old Fords. A 4000 4 cyclinder, a couple 961's an 861 and a Jubilee. Those were more just hobbies. Never really worked any of them except for some brush hogging and snow plowing. Now I have a place with some tillable that I may plant some sweet corn, other veggies and then work a couple food plots on some hunting land. The old Fords are really nice to work on but I've seen around here they just can't go slow enough for a tiller which I'm sure I'll need. I've heard the 3 cylinder diesels are slow enough but don't really know anything about them. Any input on models, options, hp or the like is appreciated. Even open to other brands then just Fords. Just looking for something to get the job done and reliable. Thanks! Tom
