200 Allis power director
Anonymous-0
I have an Allis 200 that has lost hyraulic pressure to the power director both high and low. The PTO still works as well as the lift arms but the steering does not. I know little about allis tractors and need to know what the problem might be. Any help would be appreciated
Does the pto still "work" or does it just turn when the engine is running, which it will do without any hyd. pressure. Does the pto brake work? Will the pto run a load? If so I am baffled. The pto and power director are in the same circuit. If I remember right the pressure for both is regulated in one valve, I can't remember which one. The three point and remotes have their own section of the pump.
