I know I am responding to an aged post on the forum, but researching 2010 hydraulic issues.
This message is a reply to an archived post by Jo Bird on April 15, 2015 at 23:10:33.<br>The original subject was "Re: John Deere 2010 Hydraulic Issues".<br><br> Have 63 2010 utility with ps, and load and depth control. Have 37A loader and all worked well except 3 point was getting slow. Then no ps and loader lost hydraulics and no power steering. Changed fluid and cleaned filter...washed in diesel fuel, soap and then dried...reinstalled and have ps and pressue to the loader valves(gets supply from valve under steering) and dumps into fill on left side of transmission. Power steering has been restored and Have pressure to the rear remote as engine labors when moving lever on dash. But no 3 point. Also checked priority valve to no avail. Do not have pressure gauge so have not been able to check pressures.
I have removed the top cover on the rockshaft housing and removed the plug for checking pressure. I can get some oil to come out of hole when just turning tractor over without it running. Can anyone suggest a valve to check that may be plugged. When changing the filter it was covered with some pretty cruddy stuff that resembled sludge and gook. One could understand that oil was not flowing through the filter.
I have been reading all the 2010 hydraulic issues but none of them culminate with an answer to the issue. All the forums seem to end without an answer or solution to the issue. I would appreciate if anyone or you(I am leaning on you as your responses have been very informative), could assist with the issue I have with the 3 point not operating. Thanks for any assistance you can provide.
Also, am I missing something on the aged forums when they just end and no one else responds?
