Artvandelay
I just bought a JD 2010. When I looked at it, it started and drove fine. I loaded and unloaded it from the trailer without issue. I used it around the place a couple very brief times without issue, but most recently I would only run in choke (this was never previously the case). I chalked this up to it needed a carb adjustment per the service manual, but was unable to do so because the tach cable needs replaced. This is on my to do list. I was able it use it to complete the needed tasks. Then, about a week ago I briefly needed it to move some heavy items with a carry all around the property. As soon as I got it pulled out of the barn it died, and I was unable to get it to run more than about 30 second at a time.
During all of this I began to suspect a bad alternator - the previous owner did a conversion - due to weak starts despite running for what should have been a sufficient amount of time to charge the battery. I charged the battery and replaced the alternator hoping this would fix the issue of it dying. It did not.
Lots of trouble shooting later, I discovered the load adjustment needle on the carb was EXTREMELY easy to turn. Due to the tach being inoperative, I adjusted the write up linked below, and voila she started right up. I put her in gear and pulled away, unlike before when she would die if you applied any load to the engine. It turned out the o-ring on the needle was so warn it would turn from engine vibration and was about 1/8 of a turn from being fully seated. Knowing it would quickly vibration out of adjustment again, I just took the opportunity to get it back in the barn until I could replace the o-ring.
Fifteen minutes and $1 later the o-ring was replaced, but my problem had returned. It's back to lots of cranking with very little firing. 9/10 times it doesn't fire at all. When it does it typically will only fire one or a few cylinders in quick succession. On extremely rare occasion it will start right up like noting is wrong at all. Unlike before, it will run for long periods of time before dying when it does magically start, but because I haven't had a chance to readjust the carb since changing the o-ring usually I inadvertently kill it trying to make adjustments and then it's game over. Also I worry about trying to take it for a drive because if it dies I'll be stranded.
I have confirmed with a multimeter good power at the coil. I have confirmed by way of attaching a spark plug to the coil lead that the distributor is getting good spark. When I've pulled the individual plugs to check for a spark I don't feel I can say conclusively they are getting a good spark. Initially they were VERY fowled. I cleaned them up and their spark improved greatly. That said, when crank with an attached, grounded plug, it will spark 4/5 times. What I find myself questioning is the quality of my ground. The seems to be NO unpainted metal within plug wire's length of the distributor cap. Further, it seems if I were getting good spark 80% of the time I'd get my sputtering.
I have changed all of the fuel line from the tank to the carb and installed a clear inline filter to allow me to monitor fuel flow. Fuel is flowing during cranking so I know it's getting good flow. These carbs have a fuel strainer in the carb where the line attaches. I've confirmed this isn't clogged by opening the carb drain and fuel is freely moving through the line to back fill.
At this point, I'm leaning towards one of two potential problems. Either a distributor issue, or a weak battery. Over the course of trouble shooting so much I have drained and charged and jumped the battery several times. Obviously this isn't good for them. I'm wondering if during cranking there is enough of a voltage drop to make starting difficult. But, if this is the case, why when I pull a plug do a get a nice blue spark during cranking - even if only 80% of the time? Further, when doing the spark plug to the lead wire it doesn't seem to miss a spark ever. Which makes me think distributor. If it's a distributor issue, why does it seeming magically start? Why does it (I forgot to mention above) not always but at times sputter as I'm releasing the key? This is a known symptom of a weak battery. Perhaps it's only occurring when I've been doing too much trouble shooting and the battery is weak. I hadn't thought to make not of this until now. Any ideas would be greatly appreciated as I'm not really looking to just throw money at this. Neither part is cheap. I suppose my plan for now is to get a good charge on the battery and take it to the auto parts store to have it tested. Thanks so much in advance.[/img:557556c438][/url]
