..There is an anti fouler in all 3 spark plugs. What
should i be looking for in a quality wire? ..
I thought the anti-fouler fish was smelling fairly strong
in your barrel ha-ha.. The increased temperature of the
plug is due to the anti-fouler and not due to it being
loose. Standard Ignition and Belden are fairly well
known brands that at one time had fairly trusted
quality. You really do not need spark plug boots at all,
old Farmalls 1950 an prior came from the factory
without insulating boot on the plug terminals. I am just
saying that to point out extremes you probably do not
want to go that route it is not ideal in damp conditions.
You could remove the anti-foulers and see how long
the plugs last, my guess would be not long. It is
interesting that you found the gap nearly closed on the
one plug when you pulled it out. I would guess the plug
was dropped or the gap was not even checked prior to
installation.
No one has mentioned the other part of the ignition
which is the distributor, you need to check the
condition of the contact points. Should be gapped at
0.020 inch when the distributor cam lobe is turned to
open them to the widest gap. That is the point rubbing
block is at the top of the lobe or the bump, its
positioned by turning the engine if not obvious. Also
you should check the mechanical advance, bump the
starter to see which way the distributor turns. Then
twist the rotor that sets inside the distributor cap the
same direction using your thumb and forefinger. It
should rotate that direction a small distance against
spring tension and when released spring back to near
its original position. If it does not your mechanical
advance is not working properly and needs repaired.
Ignition points condenser these days are not near as
the quality they used to be. They can electrically break
down and cause the ignition to misfire and even stall.
Installing a quality brand such as a Standard Ignition
Blue Streak can at least give you some confidence of
having a reliable one installed. Ignition coils can also
go bad and cause an engine to stall. High external
temperatures of the coil is one indication of a failing
coil.
A compression test measures the ..pressure pumping..
ability of the cylinders. All the plugs are removed, the
throttle pulled wide open and the ignition coil pulled
out of the distributor cap and grounded to a point on
the engine. The tester is screwed in the spark plug
hole and the engine is rotated about 5 turns with the
starter. The gauge then gives you a reading, I would
say a good number would be between 85 and 120. The
air is bled out of the gauge and then moved to the next
cylinder. If for some reason one is found low compared
to the others a teaspoon of oil can be added the
engine spun a couple revolutions and then retest the
cylinder. If the compression come up then the piston
rings are the likely problem. If a very minimal or no
increase this indicates a valve sealing problem. I am
attaching a link to a source for an inexpensive tester
you may also be able to loan out one from an auto
parts store, Oreileys does this if you have one in your
area.
Compression tester
