Edited: found the filter releif valve- not the issue.....still no hydraulics
Long story short- how do i remove and clean/repalce the oil filter pressure relief valve on a 2020? i THINK that is my issue- or one of them.
Longer story: I have a JD 2020 ('71 pretty sure) i got from a neighbor over the winter. Bad brake valve when I got it, had pretty dirty hydraulic/trans oil. Had someone replace brake valve, flushed lines, replaced oil. It ran fine until last week when all hydraulics just quit. No loader, no rockshaft, no power steering. Probably no brakes but havent tried to move it.
There is a small plastic line running from under hydraulic pump to above the reservoir check valve. It is not clamped on, probably was a some point in time. During operation the line came off, spilled quite a lot of oil before being noticed. This happened three times. Each time oil level was returned to proper height. Last time this happened, my father in law was brush hogging- he noticed it, stopped, put line back on, we checked oil level- and then zero hydraulics when started back up.
Hydraulic and trans pump seem to be working (filter housing had oil in it after being changed- ie trans pump is working? and hydraulic shaft turns with engine- opening plug on pump and turning engine oil pours out- ie hydraulic pump works?) Am i right so far?
Cleaned the screen- which was beyond filthy. Replaced filter. From the tech manual looks like filter pressure reief valve is most likely next- makes sense if the screen was blocked that the dirty oil got some debris stuck in the valve? Next option i believe is the pressure control valve- guessing cleaning all valves would be a good idea at this point.
Located plug on oil filter relief valve, but the tech manual doesnt give any indication on how to remove or inspect the valve itsself. Lots of gunky oil behind the plug. Can see the roller pin but no clue how it is removed- or if it can be cleaned without removing?
Found a video of a guy with a 2030 he quickly mentioned he removed his valve when he split the tractor- if the valve is the issue really dont wanna split it.
Any insight is greatly appriciated.
PS I love to fix stuff but am by no means a skilled mechanic. Learning as I go here.
This post was edited by sundreams on 08/21/2022 at 06:55 am.
