Anonymous-0
Was out pushing the extra 10 inches of lake effect today and the lowering of the bucket on the 2305 tractor stopped working proper. It would lift and dump and close the bucket fine but stopped lowering all together. The only way to get it down was to remove the lines and bleed of the pressure. Switched line controls and always the same control would not work. I think that the control valve needs to be pulled and cleaned/repaired. Any other thoughts would help. And has anyone else had this problem or is this just my luck!
Thank You again.
Thank You again.
