Pulled the 2590 into the shop to clean her up, change the oil, and get ready to do some ploughing. Discovered that there was a gallon and half too much oil in the engine.
The last time that the tractor would have been used was last fall pulling wagons. The oil would have been checked daily then and I do not remember there being anything out of the ordinary. So, I'm thinking maybe a bad front seal on the injection pump leaked by all winter.
I am going to pull the injectors and pop test them. If I see anything questionable I will take the injectors to the local diesel shop for rebuilding.
I'm thinking that while I am that far into it I should replace the front seal on the injection pump. I had a Massey that was making oil and it turned out to be a bad front seal on the injection pump (it would fill the crankcase just sitting).
So the question is: if I remove the injection pump, can the front seal be replaced fairly easily (like on the CAV pump in my Massey), or does the whole injection pump have to come apart?
Thanks,
JP.
Thanks,
JP.
