2600 fuel system problems?
Anonymous-0
I have a Ford 2600 diesel that stoped running. It seemed to run out of fuel. I changed the fuel filter with a NAPA filter. I have fuel going into the filter but have no fuel coming out of the filter. Is there a transfer pump that pumps fuel thrught the filter and where is the transfer pump located? Having a hard time finding info for the fuel system.
Thanks for the help.
Trey
Your Ford 2600 is a gravity flow system.
Loosen the connection from the tank to the filter (at the filter) and check for free flow of diesel to that point. A trickle flow is not good enough.
There is a purging plug at the top of the filter housing to allow you to expel air from the filter. Let it flow until the air bubbles stop.
The NAPA filter you bought may be for a pressurized system (system with a fuel pump)?? If so, it won't work with gravity flow. Get a NH fuel filter.
The typical diesel fuel system is a gravity flow system consisting of the tank, a strainer, an outlet valve, the fuel filter(s),the injection pump and the injectors plus all the lines connecting them.
Start at the fuel out let of the tank(inlet to the filter. Shut the tank valve, remove the line at the filter inlet and holding a suitable container to catch the $4 diesel, open the valve. You should have a CONTINUOUS rush of fuel out of the line. If it dribbles or is intermittent, check the fuel cap for a blockage of the fuel vent or the strainer upstream of the valve for clogging.
If you have good fuel flow at that point, reconnect the line and open the bleeder screw at the top of the filter. Turn on the tank valve and wait till you have a steady flow of fuel with no bubbles at the top of the filter, then close the bleeder screw.
If your pump has a bleeder screw, open that until fuel streams out with no bubbles, then close it.
Go back and make sure ALL the fittngs in the fuel delivery system are tight so they cannot suck air.
Make sure the battery is fully charged. loosen the fuel fittings at the injectors, either one at a time or all at once. Crank the engine til you see all fuel at the injector fittings and then tighten the fittings. If you do indvidual fittings, the engine will usually start before you get to the last fitting.
