265 Waukesha engine build.
Dusty770
I have a 265 in my 770 oliver that is bored to a 283 but I want to go bigger.. Does anyone know if anyone of anyone that makes 4 inch sleeves and pistons for a 265?
You can use AC-WD Sleeves. I have a set of new 4 inch JE Pistons for sale. You will have to bore the block a little bet for 4 inch set up.
Cell: 515-468-9929
Hey big motors, if I use a.c. pistons do I have to change rods to for the wrist pins? Have you ever seen a 265 block punched 4.25? I wouldn't mind having 340 cubic inch.
4.25 is easy,can even run water at that.id go 4.375 to get it over with,fill the block except the top inch to two inches
