Anonymous-0
I have a 1983 2810 that takes spells blowing fuses and won't start. It's an inline 20A. in the hot wire off the solenoid going to the ignition switch. Not sure if it's original. Anyway, I've been up to my elbows repeatedly in the harness and can't see anything wrong. New battery, new cables (hot & ground), new starter and solenoid and new ignition switch. The fuse blows when I turn the key from OFF to the first position before the START position. I've disconnected the lights & the transmission safety switch (temporarily)while troubleshooting without any luck. Could it possibly be the voltage regulator? Not much else is left. AND, it sometimes goes for weeks/months working fine. Then one day... Any ideas? Thanks in advance.
