swampranch
Hello and thank you,
I have a 2810 with an odd wear pattern, the inside of the left rear tread is worn lower than the outside and the outside tread of the right rear tire is worn the same way while the inside is normal wear pattern.
What could be the cause of this wear, or could it be considered normal? To high of air pressure, too low?
Thank you in advance for your insight,
Bob
Bob
