2870 Case Tractor
Roger Gwin
I just bought a 2870 Case tractor. Clutch 2 in the powershift has a bad leak and needs repaired. What is the best way to get to the unit ? Pull the engine or can it be done from the back ? I hope someone can advise me because there are very few in the area. Thanks
There are others better informed but just looking at diagram on case web site it looks similar to 4690 an on that one you need a stand that mounts under engine(large 4 point) an than you can disconect all lines an remove bolts on frame- disconect at bell housing an roll forward. Dont even have to remove radiator or hood on 4690.That is brief description you will do.Case dealers had special stand avaible.
