Anonymous-0
After having no luck locating an intermittent short that sometimes drains my battery between tractor uses I have decided to put a disconnect switch in. I want to disconnect power to the keyswitch & fuse panel. Can someone direct me as to the best place to put a disconnect swith in...other than on the battery poitive or negative (because of the large amperage needed for the starter)? I do know that the starter is not the cause of the battery drainage.
follow the wiring from the fuse block till it hits a power feed. OR.. follow the power cable from the battery.. On many models it goes right to the start solenoid, and all accy power also attaches there as well.
soundguy
If I were you I'd put the disconnect on the negative battery cable. It'll cost you a bit more for the heavy switch but is well worth your time. Those cables were known to chafe in behind the battery tray. Having a ground disconnect switch in there to shut things off quickly would be a bonus...
Rod
