JGCLimited
I have a hydraulic problem with a 2940. It began in the spring, with the hi/lo dropping out of hi when the idle went down. Also had some problems shifting into the 4-8 gear. I took it to a mechanic, who said he didn"t have time to split the tractor, but the transmission pump was bad, after he put a new main hydraulic pump in. I was told I could use it through the spring, and then bring it back to him when he had more time.
Soon after, I lost reverse completely, and hi/lo got so bad that it stayed in lo all the time, with the selector lever having no effect. It didn"t even make a different sound when moved to hi.
The tractor still has all it"s power (in lo). 4WD is strong, as is the PTO. When in hi, the hydraulics for the loader and steering go away completely.
I have the tractor completely torn apart. No broken line, no mangled fluid pump, nothing to explain lack of oil pressure.
The reverse gear bearing had disintegrated. So that explained that part, but some of the synchronizer rings are discolored, as if they got hot. Shifting was a bit sticky, but not enough so that I thought it was a big problem. I am thinking, between these two symptoms, that there could be a lube oil problem as well.
Any thoughts?
Any thoughts?
