Greg 2N (TX)
I just wanted to share.
The kids loved the Sherman Step-Up!
On the long straight-aways on the country roads they kept saying put it in overdrive!
Yes the parents were holding the little ones on the 16 foot tandem axle trailer.
I had an elctric brake controller wired on the 2N to the back connector with a switch.
Up for hazard lights, center off, and down for brake lights with electric brakes (adjustable current).
Man I had a good time!
I was able to stop on a dime even in the hills.
Front end rebuild and steering column/drag link rebuild made for nice tight steering!
Sorry but the hay ride was wonderful, especially for all the kids.
I was the only one pulling a trailer with a 2N, the rest of the neighbors had pick-ups, not the same! The ride was about a 15 mile trip, stopping for trick or treat along the way.
BTW, I come up with a good drawbar setup.
Made some stay straps out of 3/8" flat bar 2" wide. A buddy pressed the ends to make the angles, and I drilled holes and ground the ends to fit at the top of the differential pin.
No worries about the draft control plunger.
Also since I have live hydraulics I have a metal strap to hold down the touch control lever.
Those stay straps are so much nicer than the limit chains and paper thin stay straps!
One strap for both tongue weight and for holding down!
Also proud of the front bumper weld job for the 2" square tube receiver hitch.
Regards,
Greg
Regards,
Greg
