kevin in WI
My neighbor broke his front hydraulic pump drive shaft, in draining the radiator ato fix it, I got 1/4 - 1/2 cup of black engine oil (not the frosty malt stuff from a bad head or gasket). It uses a lot of oil and smokes pretty bad but runs actually quite nice. No coolent in oil pan, compression was 105,85,65,80 and none of the plugs looked washed. Is it possible he has a crack or rust hole from the oil galley to the water jacket? That is the only place I can think of where the oil pressure would be higher than the coolent pressure when it's running but opposite when it is shut off. thanks in advance.
