2N starter issues
Jagalonia
Just want to make sure I'm not missing something before I pull the starter out of my 2N. Saturday, I ran it for about 2 hours digging holes with the auger I threw on the back, it's not a fan of running it, probably because of all the rocks in the ground, but it does it.
Yesterday, I fired it up to dig more holes (Wife wants that fence in by last June.) it ran at lower RPMs than normal for about 5 minutes, then quit. (I let it run in neutral hoping it would figure itself out, so engine was running with no additional load). After that, I tried to fire it back up, and the starter turned, but the engine (Crank shaft?) wouldn't.
I'm not looking forward to pulling the starter out, because I've heard it's not difficult to bungle up, and I'd rather not spend the >$200 on a new one if I don't have to. Any insight would be appreciated.
If the starter is turning and the engine is not turning over, either the bendix is broke or the ring gear is spinning on the flywheel. Or maybe missing teeth on the flywheel, but I would be the bendix is broke. Time to remove the starter. possible that the benix hung up and the starter was being turned by the engine.
It's easy to bungle up anything! It sounds like you need a bendix for the starter but that wouldn't explain why it quit running. On my 8N I remove the bolts for the oil filter to get a little more room. The 2 bolts that bolt the starter to the engine are also the bolts that hold the starter together. When I get the starter loose I put a nut on the bolt to hold the starter together while I move it around to get it out. If it does come apart on you it's just another learning experience as they aren't complicated, just heavy. A good independent parts store in a rural area should stock the bendix, or a strater alternator rebuilder.
You should have one or the other starter drive. Top is the new locking design, bottom the original non locker. Arrow points the direction to spin it on the bench grinder, if fingers turn it by mistake and lock it up extended. :ROFLMAO:(can still fit it the engine extended)
The cow magnet is helping center the drive-- the puck is on the teeth, and not much space, but can see a sliver of light.
This is a sidemount 8n, but should be the same job as on your 2n.
May have pull the dipstick also.
You can see the barrel is a bit smaller than the end damper puck (or spring) trick is getting em up over the ring gear teeth.
Your engine running issue sounds like fuel starvation. Less fuel coming into the carb, than the engine was burning.
