lonewolf1
i am trying to find out all i can find out about the 2n i have a 2n with block nu 2n23623i axle2n4015a2 trans9n7.006 8i am trying tofind out if tras has been changed also any to find out if came with steel wheels i am trying to learn all i can also i have bought another 8n for 200 dollersmissing hood and steering box if you can help please con me
ok it says thay did not put 2n on serial nu but the rear end you can read good it is 2n4015a2 now we can not find a 9n on rearend but it ison trans and front hub and the 3 point arms was the 2n used on some parts ?
Look on the front side of the rear axle housing. There is a raised set of numbers usually out lined with a rectangle. They will read something like this: 2-14-47 or 5-22-44. The numbers indicate m/d/y. Check both right and left sides. If I can get a hold of the wife's digi camera, i'll take a pic of mine.
ok went and the best i can pull out is 9n236 or b23i onthe side block also pulled hood of head has 9n6050 on it also at starter on block 1246
ok went and the best i can pull out is 9n236 or b23i onthe side block also pulled hood of head has 9n6050 on it also at starter on block 1246 full nm is 9n23637i
9N began in 1939. 2N began in 1942 modified to save on strategic war materials. Except for the modifications (tires and wheels and stuff) they were identical with interchangeable parts. Parts that didn't change didn't get new numbers. The 8N was a significant improvement in 1948 with better steering and 4 speeds forward in the transmission. Still an 8N had parts marked 9N.
Gerald J.
Here is a pic of my 2n axle housing. Remember what I said in my previous post about the build date? As you can see mine was built 2-19-47, or atleast that is when the castings were made. So, with that said, if yours were a "war time" model, your casting date should fall some where between 1-1-43 and 1-1-46. That would get you real close to figureing you have a war model. I wouldn't bank on the engine serial number because they were changed out so easily..... Unless you know for a fact that it is all original.
