On my 300 U I have the 2pt fast hitch.and the 3pt conversion for top link. I have a couple sets of 3pt adapters that go in the 2pt sockets. Problem is the the 2pt "Y" frame is rigid and will not allow flex to hook up 3pt stuff. For example a simple flat draw bar can't be mounted unless I pull the bolt/pin on one side and in effect bolt it in except on the draw bar the mounting pins/bolt are integral. So, the only way to mount to tractor is to assemble the draw bar in the 3pt adapters and then poke it all into the 2pt sockets at the same time.
I have come into several pieces of equipment with 3pt hook up that are simply too big for such nonsense, ie back blade, York rake wood splitter.
Did I miss something? Or it this why the 2pt hitch has gone bye bye ?
What is the cure? Mount every thing with actual bolts? Cut a notch or notches so the 3pt "pins" will drop in from the top?
I am sure about every body who has a 2pt hitch has delt with this. What is the cure?
thanks in advance.
dave
thanks in advance.
dave
