3 point hitch fork lifts
Chances R
I have a chance to get a fork lift assembly free of charge. I was thinking about using it with my 67 3020 John Deere. Any thoughts? I would like to find a cheap pneumatic fork lift but havent had any luck yet.
I built one using a hyd. slide cyl off a rollback wrecker and 3" channel iron I use it with my JD 2440 and can stack rolled hay 3 high in the barn it works good esp if you have dual remotes using a small hyd cyl for the third point that gives you tilt control
