3 Point Hitch Leveling Screw Housing Replacement
dm2237
Hello, just wondering how you get the housing ends off the leveling arms for the 3 point hitch. Both of mine are broken, so I wanted to replace them. Thanks, Dan
Help us out a little, what tractor? You posted recently
about a IH 966. If that is the case by your description I
would say the the pin pulls out that connects it to the
lower 3 point tug arm and then it just screws off the
threads of the upper adjuster that has the crank lever
on top. Seems odd to me that both could be broken.
Forgot to mention it's on a Farmall 666 I just picked up. The left side was broken, and welded back together. The right side is is broken now, was when I got it.
