3 point hitch lifting
Anonymous-0
I have a 3320 John Deere Tractor. I recently bought a 6' Southern scrape blade. When I try to pivot the blade to cut a ditch, the 3 point hitch does not lift the blade high enough to clear the ground other then when it it is the ditch. Do I extend the bottom lift arms or cut the blade shorter or any other suggestions?
Can you slide or adjust the blade so that you can
lift the blade out of a ditch? Ditching with a
3pt blade is a problem unless the blade has an
unusual range of adjustment. You might be able
to solve that ditching problem by shortening the
blade as you mention, but I wouldn't recommend
extending your lower links on your tractor unless
you are, or have access to, a gifted fabricator
with a complete understanding of the physics and
strength of materials involved and you don't mind
depreciating the value of the tractor. JMHO
To get the blade out of the ditch where I can go down the road to the next spot, I would need to get off and change the setting back to a horizontal one. I think shortning the blade might be the best answer. I was going to put the extensions on my quick release bracket. Thanks for your quick reply!
Are your links to the rocker arms shortened to the max.? Just as soon as you shorten the blade, you will need the length for some other operation and will need to purchase a new blade. You might want to look at a pair of shorter links to the rocker arms for this operation and change them when you need to do ditching work and replace the original links for normal operation. Good Luck.
I don't know about your particular model of John Deere, but many John Deeres lift to a higher maximum point depending on where the draft control is set. Play with your draft control before making any modifications to determine if that might solve your problem. Raise the operating lever to its fully up position, then move the draft control adjustment from "full depth" to "full draft" with the engine running and see if your lift responds.
It's the nature of the beast; even on a larger tractor, when the blade is angled down, it'll barely clear the ground with the draft links up. Solution is a hydraulic tilt/swivel blade, but you're talking lots more money. Shortening your center link will help, but may change how it engages the ground.
