Hi,
I was mowing with my 300 Utility when somehow the drawbar pin fell out and caused the brushhog driveshaft to separate into two pieces. The tractor was at full throttle with the independent pto engaged at the time so it took a little time for everything to stop moving. Now the pto makes a knocking sound if I try to move the handle to the off position. With the pto in the on position there is no knock sound. I read on some other posts that there are more gears engaged/turning when the pto is off than when it is on. The problem is with whatever is still turning when the pto is off. My tractor does have the seasonal disconnect. I am trying to locate the source of the knock. The sound is not there if I move the lever to disconnect the seasonal coupling. Does that mean that the problem is in the independent pto housing itself? Or could it be the drive/driven pto gears in front of the transmission? Should I start by draining the transmission fluid and take off the covers underneath?
This tractor also has a TA if that makes a difference. I am hoping I can fix this without splitting the tractor.
